onebig76k5
Registered Member
I ordered a set of Summit Heads after discussing requirements with the Summit tech line. I installed the Heads and was about to install the intake when I noticed the head has water outlets front and rear and the Intake has outlets front and center. Can I still use the intake? Or do I need to order one that matches the water outlets on the heads?
