well my weekend started off crapy it all started out thursday night when i was on my way from base to my girlfriends house and i was coming down a slight down hill and i downshifted and i both heard and felt this loud pop. my tires locked up and i came to a stop along the side of the road. so i get out of my k5 and i look underneeth and my drive shaft is laying on the ground. after i found out that it snaped the yoke and i had been hearing this noise come from under the truck for a little while i ended up taking off the rear dif. cover and needless to say any gears that were in there are completely shot now i pulled them out by the hand full. my question is does anyone happen to know what kind of gears come stock in the 87's its a 10bolt if that helps anyone. i'm not to smart when i comes to this and when i took it to a shop they wanted to put a locker in and that was going to run me 1200 to 1400 dollars. i figured if i knew what kind of rearend was in it i could go to a junk yard and pick up a used one and put some new bareings in it for alot cheaper than that....any advice would be greatly appreciated....thanks Leroy
