Confedneck79K30
3/4 ton status
ok, almost got this thing wooped...
i took another look at the dist, and where i marked it when i took it out... and i figured, well maybe the po didnt have it timed right either, so i loosened the clamp and moved it a little, adjusted the idle set screw and the mixture screws, and it idles really nice now...
still has a little bog right off idle if i try to go wtfo... and a really small pop in the exhaust - could the pop be caused by no muffler on the one side? i figured tomorrow id buy a couple cheap mufflers and cut the pipe back to the good part and clamp them on...
