Help Rear Bolt Mount Bolt removal
RAY
Austin, Texas
Guys,
Doing some rust repair near the tailgate on the driver's side, but I am having trouble getting the bolt out. I got the nut loose, but the bolt doesn't want to put out. Does this bolt have two nuts like I do?:D
Thanks,
Ray
Not sure which bolt you are talking about. If you are talking about body mounts - Rear body mount bolts, with rust, can be a b!itch to get out. They rust around the bushing washers.
I had to cut the head off and took it out through the bottom (still stuck on the mount) when I did my new body mounts.
That is what I discovered. The washer has rusted to the bolt. I'm going to have to drop the tank to get in there at cut it off.
