Ah, ok theres my problem. I dont have a spindle nut socket for the outer nut so I've just been spinning away at the inner nut.
Inner and outer nuts are the same. The larger thing you see in that pic is the washer between the two nuts.
I have removed the two snap rings mentioned above and the internal hub assembly won't slide out. It gets hung up right at the edge... am I forgetting another snap ring or is it just worn out and being stubborn??
no go. I did that before, but this time I tried putting to more of those screws to try from a different angle and still can't pull it off
would it help to heat it up? any other ideas to get rid of that lip? I don't know if a file would work.. is it the front edge that its hanging up against?
Ok. will try that tomorrow (dark outside now), thanks
