So i had a leaky front pump seal, and a cracked flexplate. Flexplate was cracked really bad and made a tick tick noise but truck ran fine.
So got a flexplate and front seal and proceeded yesterday to have the joy of pulling my tranny/tcase by myself
Got it pulled far enough away to get torque converter off, and then flexplate and then changed seal. Had a fun time getting torque converter back on but it finally slid back into its spot.
Struggled for too long to get tranny back lined up and finally got it.. torqued all the bolts down, put starter back in, and added 4 qts of fluid.
Soo the tranny makes this horrible grinding, scraping noise at idle/low rpm. Still drives forward and reverse as i backed it out of my driveway into the street to clean my mess. It goes away if i rev it up. does it in all gears and neutral.
What could this be????? Im going to go insane if i dont figure it out. I will go grab a video and post it back on here.
