help with center bearing
bone cracker
canada
78 1/2 ton with 465/205, has two piece rear driveshaft but the shaft from the transfer case through the center bearing goes through at a bit of an angle not straight. is this normal for a lifted truck. there is no vibration but it is wearing on the rubbuer part of the center bearing a little. truck has 6'' lift with 35's. any one else have this problem. any help would be greatly appreciated
