readymix
3/4 ton status
If you have +12Vdc to one side of your injectors "481(red) and 482(white)" then you must have a broken wire or a bad ECM....unless both injectors are faulty
Yes, I have power to it.
So you have power to the 12V input TO the ecm from battery power right? Its not very likely that the ECM has failed both the grounding circuit AND the power supply leg output TO the injectors too.
If you've got no power AT the injectors, you can simply supply that with a jumper or something right from the battery if you wanted. That will for sure tell you if the power or switched ground is missing.
You need to get as close to the ECM pin terminals for the power and ground feeds to the injector and test with a noid light if possible during cranking. If that harness has a poor connection, it could be the answer (more often it is than having an ECM failure or component failure).
What's also troubling though is this comment about the fuel pump relay not activating. If that's true, it would almost seem like your ECM might have bad power and ground connection because both of those circuits failing internally in the ECM would seem to be very unlikely.
Find the power wire at the ECM and run a jumper to it.
In the case of jumping the injector. It's a good idea, just unplug it from the ecu first to prevent back feeding the electric current.
what wire did you jumper exactly. There may be a break in the wire or a fuseable link
So it starts and runs when you apply an outside power source(jump wire)? This tells us that some where along that wires travels is a break. It could be something from the wire is snapped/broken or the pins for the fuse/relay is not making connection. What you need to do is get a test light. See if it lights up at c16 at the ECM. If/when it doesn't. Follow it to the next item in the circuit. Test the wire. If it lights up the the break is between that spot and the ECM. If it does not light up follow to the next spot in the circuit. Checking for light.
I suggest a multimeter because some lights will come on with low voltage but not enough to power the component. A multimeter will let you know you have B+.
C16 on the ECM is circuit 440. That comes from the ECM-B fuse.
I have found that meters can show 12v regardless if there is enough amperage to power the item in question. A test light will be dim or not light if the voltage supply is weak. I always use a test light for quick power supply testing because of this. Light it up on direct battery voltage when you start so you know how bright it should light up.
