I decided to rebuild my tilt steering column, which I believe is out of a 1986 suburban. I ran into a little bit of trouble and have an unidentified part. I
need to figure out where this little leaf spring came from. As I took off the sleeve that houses the key tumbler, it seemed to fall out from the passenger's side of the column. I looked at a bunch of videos and combed through the posts here but can't find out what it is or where it goes. Any help would be appreciated. I was trying to put the high beam switch rod in place when I heard it fall out from the other side.
I also need some ideas on how to cover the push rods for the high beams and the ignition. The sleeve that covered them had to be cut off during a trail repair. Wish I would have thought that through a bit more, since I can't figure out how to get a new one on without completely breaking down the column way more than I want to. I need to cover the area between the two red arrows...anyone know of a two part cover for this area? Or some other way I can cover those rods? I thought I remembered someone making a clamp on sleeve as an anti-theft device for monte carlos in the 80's, but I can't find one now.
Yes, I have considered a new column from one of the many vendors out there, but the prices they are charging make me suspect they aren't of the highest quality.
