i have a place locally that has an oven large enuff for a frame & are reasonably priced, i had a 1st gen k5 frame(w/all leaf spring mounts removed and 1st gen 2wd truck trailing arm crossmember installed at k5 wheelbase), trailing arms, rearend housing, 2wd engine cross member, rear coil springs, and front upper&lower a-arms, & the front coil springs(2wd c-10 swb) and spindles(grey tape on machined areas), & new calipers(converting 69 k5 to 2wd) media blasted & black powder coated for $375(very reasonable, i expected that much just to clean all the stuff)...i dropped it off at 8am and at 3pm they called me & said it was done, i was shocked they got it done so fast(they said they had all 5 shop hands on it, b/c they were in a slow period, that ussually its a 3 day turn around, which still seems pretty quick)...i still had my trailer hooked up, so i drove 20 min. & picked it up.....stopped by advance auto & bought new rotors & pads for front and back,....by 10pm i had it all back together/rolling frame, i had all new energy suspension poly bushings & balljoints & rear u-bolts for this truck already, its now getting the fuel & brakelines installed, waiting on the bodywork on the k5 rocker boxes, then body back on the frame.
