hi guys, id like you to meet my friend sack
irishraptor87
ct
sack was born in new jersey, i found him roughly 6 or 7 months ago, i made the drive from central CT down to see him, he was a little rough around the edges, but showed potential with a little TLC
from there we had sack towed all the way back up here, little bit of a pain, but finally got it here, i spent the next 3 months getting it basically running and able to sort of drive, i took a long time re-running lines, tubes, and wires, the bed had huge rot holes in it, rockers were messed up, and a million other things, parts and oye, too much to list, carb and windows leaking, exaust made from a million different parts
sack is a 1 ton k30 with 4.56 gearing and a locked rear, 350 engine, sm 465, and np 205 combo
after some body work and repair, i got to a point where it was decent enough, started getting some paint on there, and i realized i really like the black and red combo, so i started hitting a couple parts, grill mirrors trim, what not, im happy with it
continued tweaking things untill i was satisfied just enought to bring it to emissions...
and again... and at this point, second time being there, is where the story of sack begins... the guy after pulling it out, in a very monotone voice, showing no emotion, the clutch is shot, burning up, exaust is ****, running like ****, still terrible in many ways, he says, 'sorry, didnt pass again, but you can tell when you hit that peddle, its got some sack to it', i sat there and looked at my friend, and i said, ok man, cool, and he walked away, i asked my friend if he said it had 'sack', he said yeah, now i dont know about where you guys are from, but around here, if you want to say somthing along those lines, you say it has some balls, never heard sack
since that day, it has been an ongoing joke with my friends, and it turned into the name of the truck
so i went back after tweaking
and again
well, too much gas, too much o2, blah blah blah, did waht i could with what i had, patched up the exaust with some crappy stuff just to plug it around a cat that was the wrong size, used a different carb
and finally... i passed, it was amazing
so i hopped in my friends garage and we dropped everything, i put in a new flywheel, new clutch, cleaned my bellhousing, tranny fluid xfer case fluid, rtv'd everything, looking good, no more leaks, helicoils in my intake and new gasket for the carb, new studs, nice and tight, plugs wires, timing, carb adjust, blinkers not working? fixed, new lights in places, cleaning put in a stereo system (boom bangin), headers, exaust (dual flowmaster 40s), and so much more, i fixed it all
finally it was time to start my lift...
well i knew what i had to do...
crossover steering
8" skyjacker kit for 1 ton
replaced add a leaf with 4 inch ORD shackle flip
used a 5" DIY4x4 shackle
poly bushings
custom shock mounts
6-8" stainless braided brake lines front and back (skyjacker)
jeeze i dunno what else, but look
finally i looked at many things and decided on my tires and rims
38x15.50 16r SSR radials
and
16x10 american racing black rims 4.125 backspacing
and mounted them today
i didnt want to post anything till i was done, and finally the time has come
Not 1/2 bad man! I'd get rid of those rear blocks though...
NICE TRUCK BRO....seriously sweet rig. Hopefully mine will look close to yours, except camo, 6" lift and 36" tires. I am jealous of your 38"s.
Remington
Sack is looking more like a real truck now, keep the pics coming as the sack keeps getting badder. I like it.
Looking good.
I agree you should ditch the rear blocks
& get some 4" rear springs instead.
sadly, springs cost money...
lol, i had saved for a long time to buy the lift/rims/tires
set me back a decent amount, so for now, the blocks are there
springs are the future plan tho
dremu said:
What kinda oilpan is that? Looks like a giant anvil :haha:
-- A
that thurrr is a moroso, let me tell you, before the lift, it was damn close to the front axle lol
Is a steering brace on your list ?I would think so with tires that big.I want one and I just have 33x12.50
The truck looks nice. one suggestion though. Lower the air pressure in those tires. I can tell from the pics that they are overinflated. They will ride nicer and wear better.
Nice capable looking rig! :waytogo:
I must confess, I was a little concerned about opening this thread when I saw the title! :shocked:
cool my old truck. glad you are having fun with it. sorry i sold it to tell you the truth. best of luck with it
Nice sack
Wow, good read. Good job with your rig, it sounds like you worked real hard and it all payed off. I like the red/black combo also. Keep up the good work and welcome to the CK5.:D
TBB
yay corey....i love your 1 ton sack, its very large....larger then my 3/4 ton sack...the pictures dont show much for the size of your sack...you need more pictures of ur sack posted up on here.:D
ya corey your sack is huge. taller than me and im 5'6" i love big 1 ton sacs. you need to get some pics standing next to it. or with a tape measure or something. the pictures dont do it justice
