hi/low beam help
xstream70
Newbie
honeoye falls n.y
4 light system (right now all on or all off ) put in new switch , new lights ,harness looks fine????????????????? any help please
:confused:
what year truck we talking about here? I had a 74 with an 87 4-headlight grill that had the same problem. The terminals of the high beam footswitch were corroded a bit, worked fine after i cleaned it up.
what switch did you replace? if you replaced the headlight switch, i'd say check your high beam/dimmer switch whether it be the foot switch or on the column
well I found the problem ,I found out the low beams will light up even if they are bad,I put 2 other lows in and now it works fine. :D but thanks neubanksc5
