hidden winch
wazzabie
Washington State
What winch do I need for a hidden setup?
I know an old sidewinder will work.
What model numbers of ramsey should i look for?
since your on the subject i would like to see some pictures if anyone gots any. im thinking about doing the samething
Most any winch can be mounted as a hidden winch. It's all about the mounting. I'd recommend a "foot-forward" mounting & a remote mounted control box. It's a bit of custom work & you should be quite familiar the wiring, but it is very possible.
Look through Ryoken's thread for a bulletproof & low-profile setup.
It'll at least give you some ideas.
Later,
Buddy
you didnt specify front or back.. im going to put a mile marker hydraulic 10.5k up front some day....
but for the rear...
ramsey patriot extreme 15k on 35" x 12" C steel channel... total cost... $30 from local steel shop...
