78 GMC Jimmy
Battery has already been replaced. I checked the cables, they look fine and the connections are all 100% good.battery or battery cables
Is there an OHM test or something for the cables?
ea of the test the best result(pass) is less than .5v if any are over 1v that part of the circuit has high resistance.
I have half a dozen batteries in the garage, some are brand new. I have plenty of brand new, and several used electrical cables on hand. I am way past testing. I am ready commit the ultimate mechanic's sin: THROW PARTS AT IT......Like Wes has been trying to tell you, check the voltage drop on + and - cables while someone is cranking the engine. It’s best to have a load on the wires and not just check the resistance. Learn how to use a multimeter if you don’t already know how. They may look fine on the outside but corrosion at the terminals where the cables attach or even inside the cables will cause cause resistance. Heat also increases resistance. And no, don’t skimp out on cheap $10 cables.![]()
Don’t care how you do it just get it done. I think we’re all done with this saga.I have half a dozen batteries in the garage, some are brand new. I have plenty of brand new, and several used electrical cables on hand. I am way past testing. I am ready commit the ultimate mechanic's sin: THROW PARTS AT IT......
I do not agree with the concept. But I am running low on hair!!!!! So parts it is!
Again, the cables might look fine on the outside but under the insulation it may be corroded leading to a high resistance and creating a voltage drop.So I replace the battery .. AGAIN.... And what, replace all the battery cables? The cables have already been off, cleaned, inspected and reinstalled.. So I do it all over again I guess. I verified the timing 3 times, I might as well do the battery cables 3 times as well. ... .
What were your actual timing numbers
Do you have a dial back timing light? Did you confirm the balancer mark to TDC? Are you setting timing at idle or at 3k rpms?
I would recommend getting some timing tape on your balancer so you can at least understand if you're in the ballpark.
I see nothing about the + cable from the battery to starter.I tired buying a super fancy timing light. Timing mark to rotor tip all confirmed (3 times). Checked for timing chain slop. Checked for distributor and cam gear wear. Tried timing at idle and 3K to look at total curve.
Update:
Final cooling system flush done. Put the original 180 thermostat back in. Distilled water, antifreeze etc. Flushed overflow tank. Installed a HUGE industrial 1190 CA (1,000 CCA) battery that I had laying around (tested, its in good shape). Improved the battery connections even further. Added extra ground straps.
Fingers crossed.
You say timing mark to rotor tip matches, but does the mark on the balancer match the timing tab. The balancer could be off in relation to crank/cam position even if the mark is on 0 while the rotor points at 1. I think some of us are just having a hard time with the "timing light is worthless" part.
I see nothing about the + cable from the battery to starter.![]()
www.v8buick.com
