Hubnut
High idle was intermittent for a day or two. Now it's all the time. No apparent vacuum leaks. Any ideas of where to look next?
It sounded like it was really pulling a ton of air through the tb. Is this normal? Never changed.
Where can used or rebuilt throttle bodies be purchased? How much? and how much is the IAC?
Okay, Maybe one of those computer readers would be a good idea. how much for those gadgets? Man, this new fangled stuff is unreal.
Dave,
Thanks for the help. I replaced the IAC and the truck is idling normally again. $30 at Autozone. I fiddled with the torx head bolt at the front driver's corner of the tb. Looked like it controlled the idle. this was before I asked. I didn't move it much to realize that it didnt help and returned it to the previous position. Idling fine--should I reset anything? Also, that screw was VERY easy to turn (like finger easy). Normal? Thanks again for the help!
