So I am trying to button up my turbo diesel suburban and I put a new radiator in and I am having trouble with cooling system.
First I noticed that coolant is starting to puke out into the overflow tank a few minutes after starting a drive, left overnight it doesn't come back and pressure stays in the system and vents off when I open the cap, even 2 days later.
The radiator is hot on the upper hose coming in but not on the lower coming out until it pushed enough coolant out of the way.
I suspected combustion gases and tested at several stages, nothing, liquid is as clear blue as it comes out of the bottle.
The water pump has been making some tin rubbing noises and now leaks from the weep hole so I got a new one and will be replacing it, I also will be replacing the thermostat even though the hoses on both sides of the thermostat are same temperature, hot, I doubt it is stuck closed.
I hooked up a pressure gauge on the radiator and it started climbing once it warmed up and I had to stop it and release the pressure when it reached 25psi and climbing and it reached 28psi before it started to go down with the relief valve open.
To note both radiator and cap are new and the cap seems to hold the pressure until it gets above 13psi which is how it's supposed to.
I am stumped.
A head gasket would have made sense but no signs of that happening, oil is also still clean and clear after this happening over a couple of weeks and trying and testing.
The only thought I have now is that the water pump is falling apart and is not circulating the coolant and hot spots are forming on the cylinders and creating steam but would it build up that much pressure?
I am stumped.
Everything cooling related was new. I didn't R&R the engine, just yanked it and built the 400. So yes, I'm guessing head gasket or crack for mine.
