Started getting death wobble on my 1971 Blazer (Dana60, crossover and high steer, PSC hydro assist) so I replaced the tie rod ends, set the toe, rotated the tires etc. Finally pulled the king pin springs and bushings out and replaced them with new ones. Test drove it after each thing and only noticed a slight improvement after I did the springs. I decided to put in spring eliminators and it wasn’t till I added two washers on top of those did I get it to go away.
So my question is, is high steer putting an extra load on the upper king pin causing the death wobble and wearing out the springs faster? Should I move the tie rod to the stock location to relieve the extra stress seeing that the Blazer gets driven on the street more than off-road? I’m mostly surprised that it took two extra shims on top of the eliminators to solve the problem.
The slow-motion videos I've seen of DW show that the front leafsprings seems to shift pretty wildly back-and-forth which jerks the wheel and seems to aggravate the entire event. Locking down that lateral movement of the axle always seemed like sensible experiment and possible cure, but I never bothered to mess with it once the big tires went on and the DW disappeared.
). That way, if I get a flat I’ll be able to get the lug nuts off without killing myself.
