91GMCSuburban
So what is the "right" cr for a TBI motor and how do I fine tune it? Right now, I am in between 9.7 cr (28cc) or 8.8 cr (18cc). I want to go as high compression-wise as I can with 87 oct.
91GMCSuburban said:So what is the "right" cr for a TBI motor and how do I fine tune it? Right now, I am in between 9.7 cr (28cc) or 8.8 cr (18cc). I want to go as high compression-wise as I can with 87 oct.
no.... for the Vortec combustion chamber to work properly, it needs the .035"-.045". this is precisely why you will find .015" head gaskets on MANY factory Vortec 5.7s.Mad-Dog said:Negative .015" on the deck and a .041" head gasket would give .059" piston to head clearance (ideal), for most people....
camshaft has nothing to do with static compression.More camshaft duration will also lower the static compression ratio at low rpm
when dealing with a fullsize truck, horsepower is not the name of the game. they're too heavy. the name of the game is torque.Horepower is the goal here man and every trick in the book must be used to remain in the game...
incorrect. horspower really is only an estimation, based on torque and engine RPM.Mad-Dog said:Torque is a direct result of horsepower....the more HP you got the more torque the engine produces, engine design dictates whether you got bottom end , midrange or topend or a little bit everywhere.
horsepower is still the name of the game at my house...!
