lectric80
3/4 ton status
I would say that 37's with some trimming is doable, and as a general rule you want as little lift as possible. The greater the lift, the less flex you will have. Great if you are running mud, not so great for crawling in the rocks and trails.
And yes, I run 33's on my 80, my buddy runs 33's on his 79, and I have never had issues with rubbing or hitting fenders on mine. My buddy never takes his off-road, but it wouldn't appear to be any different from mine as far as rubbing.
Believe it or not, I was placing quite a bit of importance on that chart and then using my intuitive newbie skills to worry about other issues that I really didn't need to concern myself with which lead to a pretty good case of analcranialitis.
) which doesn't give enough wheel travel. I would say ideal is in the range of 3-6 inches.
