I was running errands today and my burb was doing fine. Then at the last stop, it would not crank. All accessories and lights worked. Cables were tight, and when attempting to crank the dash lights even dimmed a tiny bit like it was drawing current somewhere. So I walked home, utilized the search on CK5, headed out with multimeter, wire, crimpers etc. to check where power is/isn't. Mainly I was going to check the fusible links.
Just for kicks I attempted to start it before probing around and it fired right up, no hesitation, no slow crank, fired up as intended.
In the past (twice in a year) it would do this, but on the second attempt it would always start.
Any ideas what could give these inconsistent results? I don't mind problems, I just wish they were consistent!
BTW, battery connections are good and clean, starter wire age is unknown but doesn't *feel* bad, somebody crimped (poorly, some wire exposed) one of the wires at the starter. If the fusible link went out, would I lose power to my accessories?
Thanks!
Thanks!
