badmix
Went on some very mild trails (can run in 2wd 80% of the time), Come over an obstacle and then heard this horrible noise, i was like WTF, did I just break a front axle? Im running Strange Chromoly axles in my 10bolt.
I pulled over and didnt see anything at first and then kept driving slowly, took truck out of 4wd just in case, unlocked the hubs. And then I realized the sound only came when I hit bumps, not on smooth, I then knew it was suspension related.
I popped hood and looked at top of shock and there was the bushings squished out both sides, so now the top of the shock was flopping around on the mount. I just took it easy and drove home, with a few bangs and clangs as I hit bumps.
What would cause this? What do you think broke? could soft suspension cause this, im running 5150s and Tough country springs, this combo makes my ride what I consider soft.
How will Bilstein handle this? Ill try to get pics later or tomorrow, im tired, we did some hiking as well as 4x4ing.
