that's why it failed.. not because of a defective bushing or wrong travel.. i'm sure the other side isn't far away....
5100 / 5160 Series
5100 and 5160 Series may only be used for specific applications. Due to the variations in lift kit manufacturers’ systems, it is the responsibility of the installer/end user to confirm that the shocks are dimensionally correct. All lift kits require lowered bump stops to compensate for longer shocks mounted into the OEM location. BILSTEIN will not be liable for damage caused by a compression impact.
Maybe add a spacer between the frame and bushing so its held in tightly.
