Stomis
Professional Amateur
Well I'm starting to get back on track in a few months with the s10 diesel, well now isuzu trooper build. I want to do home made radius arms in the front for a better ride. I place on making them from thick walled square tube or DOM not sure yet.
Gonna use ballistics brackets and coil buckets, ballistics rebuildable johnny joints at the frame, and bushings at the axle.
I want to look into the coils for a parts list I'm putting together. I'm going to be using adjustable coil buckets so I'll be able to adjust the lift and use some longer lift springs for more travel but maintain low lift.
I figure the front of the isuzu will be around the same weight as an early bronco w/ a small block, plus about 300 lbs for the diesel and winch. I was thinking maybe fullsize bronco springs or even 90s ram 1500 springs.
Thoughts?
Thoughts?
