Holley 750 Double Pumper
BDAMNRZ
Chesterfield, VA
I'm looking for a Holley 750 double pumper. A real double pumper, not just a dual feed. Mechanical or vacuum. Let me know!:laugh:
750 CFM is a lot of carb, make sure you can use all that CFM , it's impossible to make an engine run to it's full potential with a carb that is too large , but you can ,to a certian degree, tune a smaller carb to preform above it's CFM rating.
Check this out http://www.mortec.com/carbtip1.htm
A double pumper has mechanically operated secondaries
& two accelerator pumps . A vacuum secondary carb has secondaries that are operated by vacuum & only has a single accelerator pump.
Google search :wink1:
http://shop.ebay.com/?_from=R40&_npmv=3&_trksid=m38&_nkw=holley+750+double+pumper&_nd1=See-All-Categories
http://www.recycler.com/automotive_parts/detail.classified?id=RCY-196-12246656&search_zip=&class=4630
http://newyork.craigslist.org/lgi/pts/415929443.html
http://dallas.craigslist.org/pts/413084430.html
Thank's for trying to help. I know that most people over carb they're motors. A 750 will not be overkill on this motor. And yes, dual pumps and mechanical secondaries IS what I'm looking for.
BDAMNRZ said:
Thank's vtblazer, let me know. Maybe we can make a deal.
That's the idea. :D
I'll try for Monday. (up at the parts yard)
kgblazer5, what do you have? Sorry vtblazer, the speadbore wont work for me. Thanks for taking the time.
Well I thought I had it here at work but its at home so I will have to get it, may be getting rid of my Avenger cuz I want electric choke and mine is a manuel. The one 750 I have at work is a vacumn secondary.
The one I have at home is a vac secondary also but its only a singe pump I thought is was the same as my 660 center squirter which is a double pumper, they were both for my race car. :doah:
