84 k5 blazer
I have a Holley Carb feeding my eldebrock 2101 which is on a 350 crate motor. The problem I am having is that after cutting the truck off it will seep gas from the rear butterfly shaft onto the intake. It does this when I=it is either hot or cold motor. I adjusted the floats level to below the sight holes and even all the way off on the secondary side. The number on the carb on the choke housing is "8D457-2 1330", what carb is this? I rebuilt the carb with a Holley Trick kit w/ the blue gaskets, float needles, power valve are all new. Any suggestions on what is causing this? Pics at Photobucket. This forum will not let me post URL's. Search Photobucket User name "84k5blazer" to see pics of carb. Thanks.
