ArizonaK5
Finally getting back on track with my 76 K5. After spending money on going back stock with the stock Q-Jet factory set up. I ended up buying a complete Holley Q-Jet Sniper EFI system. One question I have at this time is the EFI in gas tank sending unit. There are 4 ports to plumb into 1 is the fuel feed, 1 is the fuel return. The next two lines are in question. The largest line looks to be 1/2" in size and is open on both ends. Does that go to the filler neck line? The smallest line 1/4" with a bell looking thing at the end, go to the vapor canister line that is mounted on the driver side fender area. If so, does a line go from the canister to the sniper unit. What port on the sniper? Kinda like the factory did it? I already called Holley twice and the paperwork isn't much help.
