As I am finding that it's hard or next to impossible to find 6.5 exhaust parts in some parts of the USA, and the banks parts are gold plated, I am trying to come up with some ideas for routing that doesn't cost a fortune in money or time.
This pic is from a guy on diesel place who swapped in an nv4500 but also ran his crossover pipe upward.
Knowing mine won't even compress that far and also being there is plenty of room to make it tighter if you wanted seems simple.
Seeing this hummer setup got my ideas part of my brain going.
So knowing that preturbo or st least an assumption based on lots of reading is that the direction of flow isn't a huge deal as shown in any manifold GM has ever made for any turbo system. There is always some drastic change in direction it's almost inevitable with a v8.
Knowing that the stock manifolds rout back and away from the block made me think that a Y pipe might work as a start for the turbo pipe,
Excuse my crappy artist skills,
Here's some pics of what we have to work with.
The crossover should be a slam dunk because there is a lot of area it can go, banks runs it up front. Not ideal because of the rubber in the dampener.
I think there is enough space to make at least a 3 inch pipe fit, if not little trimming is required. And once it's above the frame the turbo can go where it fits.
muhahahahaha
