Home made zero rate add-a-leaf?
jk3078
Moyie Springs Id.
So what do you guys think about cutting down an old heavy duty overload and useing it like a zero rate add-a-leaf? I cant see any reason in my head why it wont work, and should be good for 3/4-1'' of lift at all for corners depending on the leaf used. Longer center pins will be needed but the're cheap. I know ORD's are cool with the 1.5 of set and all that but I'm a cheap bastard (broke!) and have lots of springs laying around. Thanks
there are quite a few guys that cut down overload for zero rates and it works fin for them
I did it on the rear works great. I notice that the 1/2 are good for about 1/2 or 3/4 cant rember but i know the 3/4 springs are good for a full inch
i did that for my front! just from a half ton spring though i only got like 3/4" lift if that.
I know a guy here in town who runs a truck shop and has lots of old springs laying around so I'm going to dig around and see if I can find somthing in the .75-1.25'' range. As far as that goes I wonder if regular 1x2 steel strap would work or if the steel is to soft? Any way .75-1'' lift would deff. help fit those new meats. 38.5x15's on 10'' wheels with 2.75'' bs is a bit tight with 5''s lift even with the fenders cut all the way to the floor boards!
i used 1"x3"x12" 1018 cold roll.
bought it for 12.58 from online metals.
cut it in half, drilled two holes. shaved the end down.
two center pin bolts were $4.
i cut my overloads, made them the same length as the spring pearch them benched a radius on the saw cut edges. worked great. you will get more axle wrap when you go that route though. should do some kind of anti wrap bar setup.
The previous owner of my K5 did that in the rear. Except he used 4 1/2" thick cut down leafs. Had my pinion point down so far it would chew up a u-joint in 6 months of intermittant driving. At least they used one long spring bolt to tie it all together.
I'd say 1 thick one is ok, but stacking a bunch is not a good idea.
