Turned out good!
Obviously the hangers at the mufflers support the exhaust vertically, as long as they don't allow rotational movement they should be fine. If they do, need another support that prevents the exhaust from trying to rotate, or you'll end up with problems at the headers related to that. I know some of that style hanger allow rotation where the rivet is, which is why I mention it. I see there is another one near the very end, but can't make out it's design.
I'm firmly convinced 90% of the problems associated with headers leaking are related to improper support of the exhaust further back. The collector bolts and header to head bolts end up taking all the stress otherwise, and they invariably loosen up. Keeping the bolts tight doesn't actually fix the problem.
