Hey all, I just got done putting the shackle flip on my blazer. Its a 84. Shackle flip is a 4"ord. Xfer case is a 208 connected to a 400 and my 6.2.
Besides my the awful drive line vibration( another problem for another time
) A horrible grinding sound comes under partial throttle. It is only at a certain point on the throttle but gets louder as you gain speed.
If I keep my foot at that spot it keeps making the noise but if accelerate past it goes awya quick or if I let my foot off It briefly does as it goes by that spot. Now it didnt do it before I put the shackle flip on.
The trucks does have a pretty noticable rake to it. The rear went from 39 3/4 to 42 inches. Its got the original drive shaft which was pulled a bit out with the 4 inch springs but has gone back in with the shackle flip. Possible the driveshaft is contacing something inside?
Also is the rake of the truck messing with my driveline angle and Caster?
) A horrible grinding sound comes under partial throttle. It is only at a certain point on the throttle but gets louder as you gain speed. If I keep my foot at that spot it keeps making the noise but if accelerate past it goes awya quick or if I let my foot off It briefly does as it goes by that spot. Now it didnt do it before I put the shackle flip on.
Ill have to shim it I guess no dough for a new drive shaft. Ill check the measurement of the yoke. I have the axle on the middle hole of the perch. I may move the axle back 1 inch err hole to help the yoke and drive line angle.
