dirtwarrior17
Banned
in my last post i said im gonna just pull it off which i am in the middle of right now... waiting for my brother to get here so he can hold it up while i put the rtv on. The psi is ok (which i found out yesterday) its the chip that is the problem. The holley tbi has a built in adjustable pressure regulator and that is not the problem. If you read a little ways back you'll see that other ck5ers had this same problem with a stock motor after they bolted one of these tbis on. the injectors are over 4x's the size of the stock injectors and i have more psi goin to them. I haven't taken a psi reading yet but i estimated 35 because its a 13-22 adjustable regulator with a 45 psi pump. the efi shops tell me that that much psi will end up being higher than the regulators rating.
I think this will end my problems and all my i got problems posts but i won't know for sure until i get the chip. I can't just go out and buy one with this many mods. Seen people do that with hot motors and it ends up running worse with the commercial(not custom) chip than it did with the stock prom.
