Emmettology 101
3/4 ton status
Dont understand why you cant get this engine to idle, but I am no EFI expert. I'd turn down that fuel psi. Thinking about my set-up and yours, there is no way you should be having problems.. The only thing that is in your "equation" thats different that mine(fuel system wise) is your pump.
Seems to me that a 355 and a cam is not much to make even a stock tbi(and fuel system) run that terrible.
A little back history on my set-up:
89 Block bored .30 over, Scat 383 crank, Manley rods, KB Hyperu pistons, Comp Cam, Trick Flow Twisted Wedge heads(very high compression), Stock TBI manifold, Holley 670 TB, stock fuel pump from Auto Zone and stock tbi chip..
This is my set-up at the moment. It runs rich but usually idles fine when sitting. When I say usually, I get a bobble now and then at lights and when turning right, its a little gremlin I am chasing.... Anyhow. My compression is so high that even on 94 octane I get pinging. My timing is retarded to help againt it but still get some.
Granted my set-up is not even close to being right(everything working together), but I get a decent idle. My main problem is I am working in the dark.. I dont know the compression or if there are flat tops or what in the engine. My friend had the engine built by a shady guy... Last figure I heard on the compression was around 10.5:1-11:1. Then my friend burnt a valve and they had to machine the heads. The cam is another area where I dont know. It's a Comp Cam that is for a carb'd engine. Supposedly it is about two steps larger than the largest Tbi cam.
Oh and another thing, I am not running a knock sensor because my friend chose to run a PJ Gear drive....
So I am goign to side with the others who say your trying to shove too much fuel down the throat of your 355. 35psi on a TBI is way too much. Look at the other person on here running a TBI 383, they only have 18 psi. So why the need for the other 17psi on yours? Thats enough PSI for another complete TBI engine...
