brokenparts
Very sorry to hear all the problems you have had.
On a side note... what headers are your running with the big block?
just cheap flowtech headersVery sorry to hear all the problems you have had.
Holy crap!
Here's the damage from last night.
I have seriously become immune to this stuff. It happens so often i just kind of expect it and have to just laugh when it goes down.Dude, I'd be losing my sh*t right now...
The 454? It's finally torn down today. My machine shop is doing the rebuild this time for almost zero in labor and just the cost of parts ( at his cost ).Do you still need help with this?
Update for everyone. Bearing on #2 was totally shot completely wiped out the crank, cam and ALL bearings.
Machine shop is calculating some bids....
1. Possibly switch to a 496
2. Possibly keep the same setup with new parts
3. Possibly switch to a roller cam
I'll have solid numbers aND a plan on Wednesday.
Stroking is a good way to make more power and keep the same street manors, and a roller cam always sounds good to me. No break in issues.
Are you sure it wasn't a wiped lobe on cam that caused the wiped bearings and crank?
The bad bearing on #2 ground down the crank about 1/4 inch. It just ground away so much material then contaminated all the other bearings.Wow ... but why so much damage!?
Make sure when it goes back together that the journals are super clean. Don't' need that crap floating around in the engine after rebuild.
