How did you get your 38872 brake hoses to work?
y5mgisi
1 ton status
Portland Oregon
I just went and picked up the 38872 brake hoses from napa and it dosnt look like the line will hook up at the caliper.
And for the record i have a 90 suburban with 10 bolt front. What did you guys do to make it work adn work right? /forums/images/graemlins/ears.gif
Mine boltedright up to my 10b from an 82 /forums/images/graemlins/dunno.gif
[ QUOTE ]
Ya
[/ QUOTE ]
my extened lines are like that too and the mounting point on the caliper is round /forums/images/graemlins/confused.gif that's why I haven't installed them yet but I think I might take it to an bench grinder to sole that problem....
justin /forums/images/graemlins/burb.gif
[ QUOTE ]
/forums/images/graemlins/hack.gif
[/ QUOTE ]
that always solves the problem........
justin
[ QUOTE ]
my extened lines are like that too and the mounting point on the caliper is round that's why I haven't installed them yet but I think I might take it to an bench grinder to sole that problem....
[/ QUOTE ]
I installed pro comp ss lines on my 3/4 ton 10 bolt and had to trim the corners of the brake line mounting tab to fit inside the caliper mounting well. I trimmed the corners with a band saw and finished the rest with a file. You can use the washer as a guide. /forums/images/graemlins/thumb.gif
well yesterday I put on the extened brake lines... I used an bench grinder to round off the mounting point, worked out really well. also had my dads friend bleed the brake system. the brakes never felt better /forums/images/graemlins/smile.gif
