78 GMC Jimmy
So how do I calculate what lift my rig has?
Can you get the stock specs on what the distance of the center of the hub to the fender should be?
I have no idea how much of a lift I have, but I would like to find out.
, but maybe others can share their experiences. Shortening a driveshaft should be much cheaper than a new one or lengthening. They cut one yoke off with a lathe, cut the tube to the new length, weld and balance (and the balance shouldn't much). Best to measure after the suspension changes are done. That rear shaft looks too long already.
