So I've got a 76 blazer with 32x11.50 tires and that's obviously an inch or 2 bigger than stock, so what is the formula/calculation to figure out my actual gas mileage with the bigger than stock tires?
Best bet is to change the speedo gears, with that correct everything else is easy.
Example using an original 29" tire and a current 32" tire over an 'indicated' 100 mi.
(32/29)*100=110 'actual' miles. Then just divide by fuel usage for mpg.
