How do I remove 91 Jimmy Hard Top?
jim11everett
Newbie
indianapolis
Just got a '91 Jimmy, before I start tearing things apart though I'd ask the experts the easiest way to detach the rear seatbelts to take the hard top off. I owned a bunch of 76-79's, never had to worry about seatbelts in those.
Semi-related question: Where is the best source for new seals for the top? If it's like all of my other K5's, it will leak when I put the top back on as I doubt the top has ever been removed on this truck.
You unbolt the shoulder belts at the wheel well, then remove all the bolts along the the rails and header, don't forget the two you get from under the rails in the rear corners. Get a friend or two to help lift. For the seals LMC has them.
ive never had my seal leak, even after sitting all summer outside baking in the sun.
topper seals
http://coloradok5.com/forums/showthread.php?t=242577
http://coloradok5.com/forums/showthread.php?t=212041
So Friday I decieded to take a little trip to my local Chevy dealer. I thought I would see what seals were still available for the cab and topper on my Blazer. Here is a report on my little field trip. The numbers and first price is OEM the last price is LMC Truck. I ordered mine and most will be here Monday the rest will be here Wednesday. Also got better pics of the tail gate and door parts.
1973 -1991 Blazer/Jimmy
Door seal on cab body (LH&RH).......................15522764............$40.85...............LMC $29.95 x 2
Door to window seal outter............................14027775............$32.00...............LMC $19.95
Door to window seal outter............................14027776............$32.00...............LMC $19.95
Door to window seal inner.............................15569071............$32.00...............LMC $19.95
Door to window seal inner.............................15569072............$32.00...............LMC $19.95
Header seal inner - cab.................................15590455...........$57.65................LMC $29.95
Header seal outter - topper............................357490...............$52.14...............LMC $29.95
Lower side seal............................................358589...............$79.18...............LMC $29.95
Lower side seal............................................358590...............$79.18...............LMC $29.95
Tail gate weather strip...................................326934...............$77.20...............LMC $49.95
Tail gate window seal outter...........................327005...............$33.65...............LMC $29.95
Tail gate window seal inner............................327006...............$33.65...............LMC $29.95
This is my old refrence sheet so the item number is not the same as the new but you can use it for refrence. \/
like stated above, don't forget the two bolts INSIDE the paneling near the tailgate...and if your garage is the right height, like mine is, u can just back up to it and slide it off by yourself...as far as the seatbelts go, i jus unbolted em from the top n left em n tha truck...
x2, I could not get the bolts for the seat belts out of the floor so undid them from the top and left in the truck
I cut the shoulder belts off and turned them into lap belts so I didnt have to mess with them every time I wanted the top off.
And I never had any leaky seal issues.
