How do you remove the wire to the fuel pump on a tbi pump?
hidesertwheelin
Hesperia, CA
I can't find where they connect. Is there a connection in the frame rail that I can't see? Or do i just cut them and order a new wiring plug and splice them?
Drivers side frame rail, 2 wire plug, above the rear axle area or towards the tank.
There is a ground wire to the frame rail also. Drivers side behind the rear wheel on top of the frame rail. This will need to be unscrewed, 13mm ratcheting wrench will be handy here.
