How many D60 front users are running studs or bolts in the u-bolt plate?
Which are you running?
  • Studs
    Votes: 52 39.1%
  • Grade 8 bolts
    Votes: 77 57.9%
  • Grade 5 or less bolts
    Votes: 4 3.0%
  • Total voters
    133
I just bought a $60 5/8" helicoil to fix mine. It didnt even come with the drill bit, now I have to find a 21/32" bit. If I could welder that could weld on cast, I would had just welded a stud in there, oh well.
I am going to be running Grade 8 bolts. My spring packs are thin (3" EZ rides) so, the studs I've found are too long. I hope the bolts will work okay.
