mountainexplorer
I've been meaning to for years, but haven't. Torn down more than I can count. Closest thing to rebuilding an engine was a used 454 I swapped a cam and heads and gear drive onto, then a week later had to tear it down under dirty conditions and put a different crank and bearings in it. But it doesn't count cause I didn't replace rings. And two rod bearings went a week later. If you saw the conditions of re-assembly you'd understand.
And if you saw my garage cleanliness and tool selection you'd understand why I haven't done a real engine rebuild myself.
12:1 compression ratio race gas
