depends on the deepness of the pan.i would say it would take 5 qts for most tranys.but that will not refill the torque converter.that holds a good 3-5 qts also i believe.if you are doing it make sure to change the filter also.you need a new gasket aND IT COMES WITH THE NEW FILTER.
