I just run true duals. I'm not sure how much gain I would have with an H pipe so I didn't do it. The biggest reason I didn't is because I have a pto winch and fitting an H would be awkward.
I do have a problem of my exhaust donuts wearing out between the exhaust manifolds and the exhaust pipe tubing. I was thinking of installing these flex couplers so there would be less stress at that point. http://www.jagco.com/premium.htm
Anyone else have a similar problem? How'd you fix it?
When I was running the Cliffords long tube on my S-10 2.5 I was having problems with the exhaust crossover bending. I installed a flex from a 2nd gen Eclipse and solved the problem.
I started out running one of those flex sections in '96 on my turbodiesel Rabbit pick-up (all whoping 75HP!!). My yota 4x4 has had one since about '99 or 2000. I have had to replace it once. Not sure if it was a defect, or the useage, or just how they go. I will use them on the Sub should I ever get around to re-working the head pipe.
