zeroz400
Front output seal leaks on the 205. Pinion seal leaks a bit too.
. Prolly something very serious like a Bad cam,or port work needed on heads, maby a restricted intake, too low of a compression ratio could also be the problem. Oil leaks suck. Prolly one of the biggest power robbers that can happen........ Looks like its time for a rebuild .......... Muuuuu Ha ha .ha..AKbigsub said:![]()
I agree 100%. There is nothing worse than seeing a sheen on the water after one of those Exxon Valdez buckets of loose bolts clambered through. When we wheel up here, the trail boss inspects all vehicles and won't hesitate to kick one to the curb if it is leaking. But tell me, is the train of thought different when rock crawling and/or otherwise staying clear of water? I have never wheeled where there was not going to be some kind of water crossing, ie creek, mud hole, flooded field etc.
Thunder said:My engine has recently developed a small leak. Once in a while there is a small spot of oil under it and there is a little oil on the oil pan. Prolly something very serious like a Bad cam,or port work needed on heads, maby a restricted intake, too low of a compression ratio could also be the problem. Oil leaks suck. Prolly one of the biggest power robbers that can happen........ Looks like its time for a rebuild .......... Muuuuu Ha ha .ha..
It doesn't really pour out fluid but it is pretty bad. I think my rear main seal is the worst. The crate engine in the garage should fix most of that though.
Brocky said:Now my 350 is leaking... But it looks like it is leaking in front of the pan. I am stumped now.
