I need to drop the pan today on my th350 and just need to knowabout how much it will take to fill it back up. And yes i searched ALOT, I even tried wikipedia before posting this.
im pretty sure i started with 4 and started it up and added more til it hit on the dipstick correctly.make sure once its up to the filler line on the dipstick to put it into all gears and then recheck the level.should be fine from there.if you are changeing the torque converter as was said im pretty sure its around ten quarts to fill completely.
