depends on where you live.....
around here... open mudholes.. guys run rockwells and 60" tractor tires....
I just went down a trail the other day..... I have 7" lift (6" susp and 1" zero rate) up front and not sure how much in back... had 12" leafs (supposed to be).... with factory block still in.. so took factory block out and block is tapered... 2.5" on one side and 2.75" on other.... so say 9" in back......
I put a ramsey patriot 15k winch in and put the wireless antennea on the cab... well through the trail I was scraping trees with my kc's and when I got home noticed the antennea in the bed!!!!!
so now the point...... mud = lots of hp, wide tires and keep that body out of the mud.....
rocks = smaller lift, big tires, great crawl ratio
all around..... moderate lift, good hp and cautious fun....
I at one point had a 3" body lift and 12" leafs on my truck... was going to go to rockwells and 53" michelins.....
so now my truck is alot lower..... anyhow.. I am in the process of trying to track down a 10,001 or bigger gvrw cab... crew cab.. if I can find one I will put it on.... add a 3" body lift and probably be done with that..... right now I can tuck my hawgs into the wells and wouldnt mind a few more inches of room...... and I already cut as much as im going to......
p.s. notice a front shaft in that pic....
some more for ya to look at....
http://rootbreaker.no-ip.com/PROJECT_NJLEGAL/htm/pics.htm
main page
http://rootbreaker.no-ip.com/rootbreaker.htm
here is some jerzey trucks for ya
my favorite is this one.....
shorten the frame a bit....
