How much PSI when towing?
UseYourBlinker
1 ton status
What PSI shoud I run when towing a horse a trailer which all together is about 5,000 pounds? I am running 33's
Eric
from Freekmont,CA.
<a target="_blank" href=http://www.community.webshots.com/user/vwryda>The darker side of nonsense...</a>
I can hit about 35-36 psi max--but I guess you're probably talking tire pressure.
I'd say probably max pressure for the tire (around 35 psi?). 15" wheels?
Pete
'83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
'97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
Yea...33/12.5R15
Eric
from Freekmont,CA.
I'd run 35psi if thats max... If you can go higher I'd run about 45-50. Remember, You'll need 10-15% tongue weight. roughly 500-700lbs. Be careful, thats a lot of weight on the tail end of a K5.
When in doubt, slow down, esp with a trailer. I'd also make sure your trailer brakes are working.
John
<font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
