If you haven't done anything yet just ask the driveshaft shop where they want you to measure from and to and they will get it right for you. Not all driveline shops measure the same way so be sure to ask the shop that's going to do the work.
My factory 89 rear 10 bolt had a shorter "pinion nose" than the 14ff that replaced it.
and i would get a cv shaft made for it, but i plan to put a 205 with a sye in and don't want to drop a ton of money into a driveshaft that is going to get replaced eventually anyway
