How much toe??? Need help
Bowtiedad
Rochester, Indiana
How much toe in do i need to get it close. I just bought the truck and it has new tie rods,ball joints,drag link and raised sterring arm, but the tie rod is adjusted too long. It is a inch wider at the front of the tires than it is at the rear of them. By the way it has 35's and a 6 inch lift it matters. Thanks Jim
that size tire 1/8 min to 1/4 max. these are for toe in specs. so as the tire pushes out it will be stright.
