urbex
The TL;DR version -
Looking to change out the stock peanut port heads on my otherwise not stock 489ci stroker BBC for some better aluminum heads (heh...as if the peanut ports are a tall bar to clear, lol). I'm trying to get a better idea of how to choose specs such as port volume, chamber size, etc., I've been reading dozens of pages on it, dozens of forum posts, and understand what the various specs ARE or how to measure them, and have tons of pages of generalizations (huge ports are bad idea on small stock motor, tiny ports will restrict high RPM power, smaller combustion chamber means higher C/R, etc.,), but not finding much on how to correlate all those numbers to my motor, and what I should be looking for.
The longer details -
About a year ago I put together a 489ci BBC for the K5, which was supposed to be a dirt cheap 454 swap to replace an overheated/seized 350...then due to my butter fingers, dropped a piston on the ground, which bent a skirt, and long story short..it became a less cheap 489 build.
I used a Scat complete balanced rotating assembly with -12cc domed pistons, Summit Racing 1789 hydraulic flat tappet cam (309 duration, .514 lift, 108LSA), Trick Flow valve springs, and reused a relatively fresh set of peanut port heads. Should be around a 9.5:1 compression, though I never CC'ed the heads to get exact numbers. I knew the heads would limit the motor, but again, was supposed to be a dirt cheap motor...I reused everything I could at the time, including factory 80's truck motor cast log manifolds with a very cobbled together exhaust that was a half-arsed combination of the factory exhaust off the '85 truck I pulled the motor from and the 2.25" dual exhaust the PO installed on the K5....though I have a set of new 2" primary/3.5" collector long tube headers waiting to go on.
Now, I'm ready to do something about those heads, but just not sure how to make sense of the bewildering array of choices out there, and don't really want to play a $2,000+ game of eenie meeny miney moe...
