How to disconnect the front wiring harness clip from the Junction block
gotblazers
Vermillion,SD
Fellow ck5er wants the front wiring harness intact off my 88. Having some trouble pulling this off the junction block. Can anyone give this dummy a little step by step direction here so i dont screw up the most important part of this harness. The connection farthest to the right in the picture is what im trying to pull undamaged.
fyi 88-up to 91 went diffrent shape plugs than old 73-87 style.
and 1 bolt in center and pull wiggle and pry it out as its sealed with vary sticky stuff.
then it just unclips from its self in to 3 sections. front clip / engine bay / rear wires to lights and such.
My harness looks different and it's an 88 also, maybe because its a suburban, still one bolt in the middle, and two bolts holding the fuse block to the fire wall
i think its cause he is working on a 88-up truck . look at the inner fender tab in white. its a 88-up truck for sure. the firewall pic posted looks like a 88-up style not our 73-87-91
the 88 blazer/burban/crew cab still had reg lights. then 89-91 thay had option of quad lights like the 88-up. thats when thay switched if i was a betting man.
:doah:
Makes sense now, I almost forgot the 88 trucks were the newer body style
